Looking for WCC Long Shift Linkage /Kickstand
Last Post: birrelly
Posted On: 12-13-2018
Trade WCC shift linkage
Last Post: birrelly
Under seat access with molded style ( pics inside)
Posted On: 12-12-2018
Parts For Sale
Last Post: Matt S.
Posted On: 12-09-2018
Building CFL
Last Post: fifty
Posted On: 12-06-2018
Old 02-21-2018, 02:40 PM
Weird constant alarm sound?
I got a custom build with an S&S SB100 engine a couple months ago - took it to my local wrench and had carbs rebuilt and general service done (oil change, new battery, etc.).
Weather isn't conducive to actually riding it here in the frozen tundra, so it's on a trickle charger and I start it every week or two and let it run for at least 15 minutes to warm up - but I'm getting a weird "EEEEEEEEEEEE" alarm sound when the key is turned on - and that sound persists the entire time it's running until I turn the key off.
I would guess it's a low oil pressure alarm, but that just got changed.
Any clue what could be the root of the alarm sound?!
Kevin
Old 02-22-2018, 12:08 PM
Kevin
What do you mean ' alarm'?. Can you locate where the sound comes from? Sounds mechanical , air or like electric humming? Did it do it before, when you just got the bike? Do you have the sound with ignition on, but without engine running?
Old 02-22-2018, 06:36 PM
Loud electronic beeeeeeeep - starts when turning the ignition on, before even firing up the engine - doesn’t stop the entire time.
Got the bike two months ago and was fine until two weeks ago, when this started...
Seems to be coming from the rear of the engine, or the transmission.
Weird!
Kevin
Old 02-22-2018, 09:40 PM
ecir45's Avatar
bike have breakers? pull the load side off till the noise goes away to narrow down the fault.
113" El Bruto / 5 speed
Old 02-26-2018, 07:38 AM
Definitely electric, like a resistance humming, like some component under straining electric load.
Yep. Turning the circuits off on by one might give an idea where the culprit it[granted you know your electric system]
an example of normal 'eeee' sound: You might hear that briefly when starter strains to fire up very big+ cold engine- till it turns. But not otherwise.
I hate to hear it.
Old 03-03-2018, 09:27 PM
Problem solved, and canít believe it...
The horn button sticks!
The horn on this bike - like most bikes - is honestly pretty anemic...
Face it, horns on bikes are next to useless - especially when the button sticks and thatís not what youíre expecting.
Ok, hanging my head now, but wanted to close the loop on this.
