Posted On: 04-05-2020
Last Post: chopperfugger
Pushrod u still on here?
Last Post: fifty
Posted On: 04-04-2020
Posted On: 04-03-2020
Old 07-02-2017, 06:55 PM
Bike Year, Make, Engine: 2017 road king 107
First chopper build looking for all knowledge and opinions!
Hows it going i just bought a pretty sweet frame and it will be my first chopper build , just looking to see what options there are for this frame i understand most of it will probably be one off or so..... only thing i know is its a softail frame with right side drive 300
thinking of using a ultima el bruto 140 but dont know where to g o from there!
Old 07-03-2017, 06:42 AM
Congrats.
I wonder, how Ultima big inch engines hold up in Arizona heat?
I hate to get stuck in traffic even with my 127 here, in NJ during summer.
I probably overreact, but when it's 90 degrees or more, i prefer to run my 96" or 113"
Old 07-04-2017, 10:20 AM
midnight's Avatar
Bike Year, Make, Engine: 2011 MMW 113 cu.in Pro Street
Looks like a similar frame to mine. I used the 113 Ultima and no complaints. The battery compartment is very small so it can be a challenge getting this thing started once the battery is more than a few months old. I wrote a detailed blog about my adventure so you may find some useful information there as well as from build threads on this forum.
Old 07-04-2017, 02:39 PM
Honestly anything from the 113 up will make plenty of power. I like the 113 because it has a longer warranty but I havent seen major problems with the Ultimas usually minor things if any. I just had a 127 with low or no oil pressure right after start up. They sent my customer all the parts to fix it. The 140 has 0 waranty. The 140 is a little taller than the 127. (just under 1/2"). The tightest spot will be the rear rocker box.
Once you decide on an engine you will need a primary or belt drive to link the engine to the tranny. RSD trannys are scarce sometimes so you should grab one when you see one. Ultima has just got a bunch in they we out for over 6 months before these came in.
I can hook you up if you need anything from parts to just bouncing ideas or fitment questions off me. Just shoot me a PM here or an email using the link below.
https://scootersperformance.com/contact-us/
The frame looks like a decent frame. Do you know who built it? You should have an MSO with that info. You will need the MSO to title it in most states. AZ I think is the most lenient for builders.
