TP engineering 107
Posted On: 02-21-2020
Posted On: 02-20-2020
Starter torque dpecs
Old 05-28-2017, 05:00 PM
beerman1378's Avatar
Light blew on my ignition
The status light blew on my Dyna 2ki. So, I'm going to have to time the 127 with a light. I guess the total timing should be about 26 degrees. Should I mark the flywheel on the 25 degree mark or the TDC mark?
Old 05-28-2017, 05:17 PM
Depending on your timing light either way will work, however, I'm not sure I'd trust the unit if the status light doesn't work. Could be a dead LED or it could be a precursor of an upcoming failure of the unit.
Old 05-28-2017, 05:19 PM
That would be the second Dyna2ki in 3 years that shit the bed! I'm gonna go broke on ignitions!
Old 05-28-2017, 07:33 PM
The same ignition as Ultima. I have them on 4 bikes. So far they seem to hold for a few years . 2 came with the Ultima engines - factory programmed. Run fine statically timed.
2 I bought for my s&s engines as crane 4 ignitions on them had died from the heat. Also statically timed.
Initially I used switches for curves and modes. Unfortunately -no switch for kick vs electric start. Only can be programmed via pc- setting 2-3 dead revolutions for the starter.
Later I programmed them through pc using software that I had downloaded from Dynatec site and a cheap interface cable from e-bay.
