Back again!
Last Post: Daxcobra
Weird constant alarm sound?
Last Post: ecir45
Posted On: 02-22-2018
Posted On: 02-21-2018
Old 04-27-2017, 08:43 PM
You have to make sure that the plunger is not pushed in too far while bleeding or it will cover the fluid hole..then there is no way for fluid to enter ..that tends to happen with fresh install sometime..the spring should keep it fully retracted.unless new plunger is stiff. I learned that in this forum..guy was having the same problem..
Old 04-27-2017, 09:41 PM
ecir45's Avatar
Try to reverse bleed the system. Can use one of those oil tin pump cans if you have one or something like a large injector syringe.
113" El Bruto / 5 speed
Old 04-28-2017, 09:49 AM
Tx51's Avatar
During some research...i found this. Below is what i had in my master cyl. Since the controls are from joker, i figure keep it same. I hadnt taken this out till a day before i recvd the new one so i assumed watvi ordered would look same
This is wat i ordered and wat is now in the master cyl. Now
Its a 9/16 bore, i never even bothered to look elsewhere since these were joker master cyl, in their website it says those parts were specific to joker masters....is this my problem or can it still work?
Chesty Puller
Old 04-28-2017, 06:55 PM
You said that the new plunger fit in nicely..why don't you take your lever off and pull the plunger out slightly and see if it is blocking the hole..then see if fluid will pull through, or pump through, using a screw driver to push the plunger and making sure it is retracting back fully..
Spring then cup then piston, make sure the piston is back far enough for fluid to drain from the reservoir into the bore.
