Club Chopper Forums
-   All Chopper Talk (http://www.clubchopper.com/forums/all-chopper-talk/)
-   -   String of bad luck (http://www.clubchopper.com/forums/all-chopper-talk/115867-string-bad-luck.html)
poppinsmoke 03-28-2016 11:22 PM
String of bad luck
So after inheriting someone else's unfinished project I have been chasing my tail trying to keeping the bitch on the road.
Bike is a Custom chrome El Dorado kit with a revtech 88 and 5 speed.
Shit like bent wheel flanges, the bike being wired by Ray Charles, pretty much every spacer being wrong, brake pads backwards, etc.
After chasing down what I thought were most of the problems, I had her on the road and life seemed good.
Then the stator took a shit, I replace the stator, rotor, and reg, no big deal.
I even figure out why the stator took a shit loose battery cable arching so bad it melted the positive terminal; so she gets a new battery too.
Perhaps I had one to many beers while doing the job, a few days later I am riding her and the the bottom end in knocking like it's got a warrant.
I cross my fingers and open the primary and find the problem pretty quick, the compensator pulley is loose and my drunk ass left out a spacer.
I take care of that and button her back up and it's all gravy, till I pour the primary fluid in and after about half a bottle is starts to pour out as fast as I can pour it in.
It looks like its coming from the drain plug but after eliminating that as the source, I notice that it coming from 12 o'clock postion above the plug on the back side of the inner primary.
I can feel a groove that has been worn into the inner primary that lines up with the lower half of the drive belt, I assume came from the shit show that was the spacer snafu when I bought the bike.
I never felt or heard any grinding and the belt looks good no sight of damage.
It doesn't seem to have worn a hole as I can shine a bright ass flashlight past the clutch basket and not see light on the other side.
So fo the leak I am thinking transmission shaft seal but I didn't think the fluid climbed that high during a fluid refill the fluid wasn't even to the bottom of the clutch plates.
I cant' touch the bike till the weekend, but I am going crazier trying to figure this out without yanking the inner primary.
I am glade I have the Garbage wagon to ride, so at least I am not stuck in a cage.
Any thoughts?
Thanks in advance for any and all replies.
madmastiff 04-02-2016 01:16 PM
... the compensator pulley is loose and my drunk ass left out a spacer.
Any thoughts? Thanks in advance for any and all replies.
wow-wee
appears most of your problems are self inflicted.
drink some more while your driving and it's gonna end up miserable and you'll be a statistic
poppinsmoke 04-08-2016 04:47 PM
It was a joke, I drank a few beers while working on the bike not riding it, but I did say thanks for any and all replies, BTW you left your soapbox
pushrod243 04-08-2016 07:28 PM
Are the bolts in the inner tight thats about where they are. hard for it too leak anywhere else just sitting on a work bench or lift since the fluid isnt that high
poppinsmoke 04-10-2016 04:51 PM
I will check that as soon as OT calms down at work, thanks for the suggestion.
