Last Post: jgs348
uh oh...chain
Last Post: magnum45pete
shock bolt softail
Last Post: kidchop
Last Post: jaybird74
06' XB12XUlysses questions
Old 02-07-2013, 09:54 AM
chopper nate's Avatar
Paughco rigid frame bobber build
I think the stock Harley Softail rear caliper and stock spacers should work for a Paughco softail swingarm accepting the 130 rear with belt, but how about a Paughco rigid that accepts the 130 rear with belt? Make things easier for me.
Nate
Old 02-07-2013, 12:07 PM
The stock spacers and caliper mount will work on the stock style rigid, but I think you might have to weld up a frame tab for the caliper.
My first rigid frame was a Paughco and it didn't have the tab already welded.
Old 03-05-2013, 07:46 PM
choppers_rule's Avatar
Bike Year, Make, Engine: 87 Rigid Sporty & 07 WCC project
Yup...you have to weld the tap on the Paughco frame.
Keep it low,rigid, and loud!
Old 03-06-2013, 03:12 AM
hanger's Avatar
Bike Year, Make, Engine: 85 WIDEGLIDE/01 ELECTRAGLIDE/91 CHOPPER
If you don't specify at the time of order your using a softail rear brake then you'll probably recieve it without the tab...........they'll leave it up to you to decide what you want to run. I specified the softail brake when I made the order and they welded it on.
Old 03-06-2013, 07:42 AM
That would be the way to go.......be done/proper w/it......
