Old 04-06-2004, 06:12 PM
SapperLohr's Avatar
SapperLohr SapperLohr is offline
Bike Year, Make, Engine: Custom Chopper/Home-made
Re: Hard Core II builders
Originally posted by Punisher
To all the Hard Core II builders.
I have one for ya. This stupid rear fender strap. What bolts did you use to mount that to the frame,,, and how did you attach it to the rear fender??
I was going to bolt it to the frame, and weld it to the fender, but getting the placement of it is a bit tricky. I do have the other three fender mounts drilled, and tightened. But this strap has me thinking….
How did you guys attach the strap to the fender? And yes pictures are worth a thousand words.
Punisher
I had to buy new bolts as well. I am using a double-sided tape used in horse-trailer construction to attach the fender to the hanger, in case the next owner ever has to remove the fender. It is expensive, but lasts forever.
W.J.Lohr IV
Drill Sergeant, U.S.Army
Airborne, All the Way
If we are the only intelligent life in the universe, at least there's a finite number of idiots
Just when you realize life's a bitch, it has puppies
