Thread: SSW+ breathing
Old 06-17-2006, 03:43 AM
racechopper racechopper is offline
I did read about crank venting:
"If installing a hose in the lower case breather location,
DO NOT use a hose by itself. Lower engine
case breather hose must be fitted with S&S #50-
8122 one-way valve. If the upper rear head
breather location is also used, it also must have a
one way valve installed. In either location, white
end of valve faces engine.
SSW+ engines breathe differently than Evolution
style engines. Not installing the one-way valve
will result in a direct engine vacuum leak, affecting
performance."
How does this S&S one way valve look like.Mabey like in head vent pic before.Can´t find it in regular catalogs ?
