The 2 terminals means its a dual fire coil , both plugs firing at the same time , one cylinder having the exhaust valve open.
3 terminals is a single fire coil ,each cylinder firing independently of the other
You'll have to wire the bike one wire at a time which is a long and arduous process and not advised.
Get a manual with a wiring schematic and isolate the wires one by one.
Good luck.
