Ignition box terminals
I trying to convert my on/off switch to a key rather than a toggle switch. the issue Im having is the ground wire must have a short because I'm not getting any continuity from negative side of battery to black wire coming out of ignition block. I have attached two pictures what's the two terminals coming out of the ignition box and do I have to use them? Just to be clear the switch I'm installing will run to the on off switch on the controls so once you turn the key you will have power to the on off switch on the controls.
