Old 11-01-2021, 11:23 AM
Oldsmobile5798 Oldsmobile5798 is offline
Bike Year, Make, Engine: 2006 Custom Chopper Ultima 113
SO, no I don't have any oil to speak of draining into the sump/ The oil level is where I left it, exactly on the weld bead bottom of oil filler neck. I'm sure in a months time like you and others have said there will be something that has leaked down to the sump. There was about two quarts down there as it had gone through spring and summer before I could get the motor running for even 5 minutes. I went through three batteries in total. Two Anti Gravity batteries and an AGM. Two out of 3 were under sized and one I left connected about a month and it was at about ten volts when I discovered it was low, hit restart button and nothing. It was out of warrantee plus it never regained its full voltage.
