  #65 (permalink)
Old 09-16-2021, 03:47 PM
JamesS JamesS is offline
Thanks for lookin'.
Electrical assy continues with the install of the led turn sigs. These are red for lighting /brake and yellow for the turn signals.
Look ok:
And the rear axle , an important piece , supplied as a hardened steel rod with threads on either end. I know how critical it is to have the rear axle stable and secure. Looking to the stock Harley item we see one end with a nut welded on. As I was looking at the parts making a plan , I noticed that rectangular washers would help keep the axle from turning.
So I made some 1/8" washers , welded a nuit on one end ofthe axle trapping the washe in place , I then tigged the washer to the nut:
And installed you can see the axle will have a tough time rotating if it came loose:
I may take the other rectngular washer and make a lock plate for the end with the nut.
