Old 07-22-2021, 04:12 AM
ball75 ball75 is offline
Bike Year, Make, Engine: custom 250 pro street, 127ci black gem
Charging system issue
I have got a 2 pin stator and my rectifier has the same 2 pin plus an extra wire. I am assuming that wire should run directly to the positive side battery with a fuse right? The charging system kit I got has no directions and the wireing diagrams I found on the internet have more wires than what I have. Mainly a "trigger wire and separate ground wire. I have my rectifier mounted to the front monitor mount bolts with a steel bracket, that should be enough to ground it out right?
On top of that, is that 2 pin directional cause it fits both ways in the hole. This isn't the exact system but same looking thing. https://www.denniskirk.com/v-factor/...prd/209980.sku
It's on my ultima 127 250 pro street. Thanks for the assistance!
