Old 01-21-2021, 01:51 PM
MAKO6's Avatar
MAKO6 MAKO6 is offline
Also, did you provide +12VDC to both the +5VDC power supply and to the orange lead into the right mirror (needed for the battery light) but also to power the LED's. Understand that your +5VDC is needed for the logic chip and readout controlling the MPH and RPM ... all of your other LED indicators (neutral, oil, blinkers, beam etc.) in 12 VDC systems typically run on +9VDC - 12VDC... I did not design them, they may use lower voltage LED's behind resisted circuits but that really wouldn't matter if you stick to the wiring as designed.
Uncomplicate things, and do yourself a favor.... buy the right power supply from Badlands... it will work the way it is designed to work..
Mak
