Old 08-04-2020, 07:32 PM
Shovel52 Shovel52 is offline
Obtaining a plate would be no problem, but what would that do to the other side of the bike when you move the trans? They have double link chains you can research. Will adding another chain width clear all that? then experiment with some shims?
kind of hard to tell since your pic. is on an angle......muck I didn't read your post, I guess if you used an off set plate , you could offset the primary with it..
