Old 07-14-2019, 06:21 AM
Am4wag Am4wag is offline
Originally Posted by pushrod243 View Post
Does your spacer have a tapered edge? It should clear the quad seal if the tapered edge is towards the inside
Yes it has a taper.Old quad ring was cut.Probably why there was a leak AND the sprocket nut was loose upon disassembly-not drawing up.Maybe pinched-why I'm at a stop because the new one doesn't want to "draw into" the taper when compressing the spacer to the drive dear snout leaving a gap between the two.
