Old 05-31-2019, 11:55 AM
Shovel52 Shovel52 is offline
The only part of the starter that is under the primary cover is the starter jack shaft gear..The starter is mounted above the rear of the tranny, and you should be able to access the
solenoid from the other side of the bike..( the solenoid is mounted to the starter) depending how crowded you are, mine is really easy to get to. Just pull the small wire off the solenoid,and check your 12v when you push the button..and then go from there..
