Thread: Oil
Old 01-23-2017, 08:54 AM
STEINBVG STEINBVG is offline
HI TX.
1)i typically have just about 1 cup of oil coming from the crank case drain.
2)Some sludge in the oil tank? can probably stick an air hose into the draining end and blow some air see it it improves. also, when i drain the oil tank - to speed up i have the cap off.
3) Always hated the braided lines, but if the bike demands it- there are special clean looking end cups for them, but the screw type clamps inside of those go against the braiding any way.... if the line keep popping out of the cup- eventually it will fray( and cut fingers)
