Old 05-25-2016, 06:57 PM
Shovel52 Shovel52 is offline
Yes, cntrhub is where we get our best information in here.....To add to this I have tried to find an answer to your question about the light coming back on and see nothing.....But according to everything else, you have done the timing correctly..
Have you done an eyeball test on your spark? Pull the plugs, hold your finger over the spark plug hole,.....kick it over... and see if it sparks at the same that compression shoots out....you will have to have someone help you..if you have the above criteria, then it should run or at least try to crank......then look else where for a problem.....
