Old 05-21-2016, 07:14 PM
Shovel52 Shovel52 is offline
Really sounds like the solenoid....Your best test at this point is to take the cap to the solenoid
off ...press the starter button and if the starter does not engage you can depress the solenoid by hand ...play with it ..your contacts are probably burned.....this is very common..you should be able to easily access the solenoid with out removing anything...there are many threads with this intermittant hair pulling problem..I actually bought a rebuild kit for mine but returned it..it was too easy to just clean it.
