Old 05-07-2016, 08:42 PM
Shovel52 Shovel52 is offline
In future tests, forget about the ohms test, it is not always reliable...coils can break down under load..just scratch the coil to ground and you should see spark, if so, the coil is good.............You can't switch wires around on a singe fire unit,.....only on dual fire ignitions.....you said you swapped out the dual fire coil, but was unclear if you switched out the ignition module with it.......Let us know if you have a singe fire unit set up with plug wires on correctly..
