Old 06-06-2015, 04:53 PM
jp709 jp709 is offline
Thanks for your reply..
It has led tail lights. I have measured the voltage and in run mode the leds have 5 volts. When the signal is applied it is 12 volts . as it flashes on and off it alternates between 5 and 12. the brake switch also has 12 volts when either the front or rear brake is applied .The problem is if I attach the brake switch wire to the rear led it will work as long as you don't use the signals.. When the signal is applied it won't flash because the 12 volts is present from the brake if it's applied. A relay might be the answer but hoping someone might have already did this..The 2008 I mentioned is a bit different in that the signal has priority over the brake light .. Doesn't seem to be that way on the 06..
