Old 01-28-2015, 12:15 PM
Shovel52 Shovel52 is offline
I don't think using as a stensil would be feasable. Just apply as your graphic and then clear over it, thick clear, sand once , clear again, thick, then final sand, polish it out. It will come off with blow dryer if you mess up. just use lots of water so it doesn't stick until you get it where you want it. Its cut with a lazer and really looks pro. Here is some stuff I did recently to cover up oil lines , wiring etc. Here is another thought, I wonder if you could just paint the vinyl graphic with your desired paint and then apply? be worth a try, and stopping by a sign shop and pick up some scraps and try it!
