Old 07-12-2014, 04:58 PM
STEINBVG STEINBVG is offline
A few additions to the bobber project
Made a hand shifter from a steel pipe and pep boys knob . The green harley neutral indicator is inserted on the top. The similar tiny oil light will be inserted on the top of the motor plate and the blue high beam- will be incorporated on the headlamp.
Started to install the fender. About 1/2" from the tire. Perfect radius. Thanks to blue collar bobbers. Changed my mind about rear mount when accidentally saw a Vulcan engineering RSD primary spacer laying around...never used. It had perfectly matched radius to become a mounting hardware for the fender.
