  #65 (permalink)
Old 10-08-2013, 09:08 PM
DIABOLUS DIABOLUS is offline
Reworked the program slightly and adjusted the workpiece origin. Cut a new piece of stock on the fixture and polished the machining marks out:
Tried to mount the Brembo caliper to the bracket and found the brake pad hit it in two places: I miscalculated the minimum arc diameter allowable. So I machined two recesses on the backside where it would not be noticeable:
Final mockup:
You can see here where the brake pad just clears the bracket:
Overall I'm pretty happy with the design but I wish I had located the bolt hole for the anchor rod closer to the caliper bolt hole. I don't know how much leverage the caliper will put on the rod but the bracket would take too long to redesign and I had very little time left in my machining class and one last project I wanted to tackle...
