Old 09-09-2013, 07:45 PM
bikefreak600 bikefreak600 is offline
Originally Posted by Boogeyman View Post
I'm pretty sure that Yes, you can use any 41mm fork tubes, but I'm not sure about the spacer. I don't see why you couldn't just make a longer spacer, but have never had a frontend that long so I don't know. Pro One makes pretty reasonably priced tubes, you might check their website for info if no one else chimes in?
thank you sir. i will google pro one see what comes up.
75' ironhead S&S 74'' kit .060 pistons. Sifton Titon cams, Ported heads w/ stainless valves, Super E, Bandit machineworks clutch, crane hi-4, stretched frame 6''out & 3''up, 40deg rake. wide glide front end.
