Old 12-31-2012, 11:30 AM
CloudDiver's Avatar
CloudDiver CloudDiver is offline
And here with springs and spring mounts bolted in... I didn't take any pictures of that part, but you get the idea. When I blast this old paint off the frame I will weld the top part of the spring mounts and close up the hole on the bottom of the tube.
See the electrical mess under the seat? I'm going to clean that up later by moving the ignition coils out to the motor mount which will leave way more room, then fab a cover plate for the battery box, an idea that came from flysocal77's build. Check out his Living Room build thread and see the finished oil tank painted by Hot Dog, killer.
