Thread: 79 shovelhead
Old 08-27-2012, 04:19 PM
shovelslim shovelslim is offline
Originally Posted by Captain America View Post
Welcome to CC! Delkron cases have a drain hole in the case to drain the oil from the top end, stock cylinders drain the oil through a hole in the cylinder wall. If you have cylinders that are set up to drain through the case and are using a stock base gasket no oil will be able to return to the bottom end. Has this engine been running and this just started happening or is this a new build?
I only done the top end after taking the jugs off their r drain holes in the head n jug but none in the block do o need to drill my own?
