Old 07-26-2012, 12:57 AM
CloudDiver's Avatar
CloudDiver CloudDiver is offline
The rest of the fender bungs were pretty straight forward. Line them up, tack them in. I'm not using the washer welded to fender trick... I have something different up my sleeve which I will reveal after paint during final assembly. For now I will say that I'm using leather washers I got from Low Brow Customs ($5.95 for a bag of 10) and I also used 2 stainless washers to act as spacers to account for paint and bodywork build up.
Here is each side tack welded into place with the washers. I used a sharpie to race the outline of the leather washers and then center punched and drilled the fender bolt holes off the bike, then mounted. You'll notice the radius is still way off in the front, more on that later.
