Old 07-26-2012, 12:26 AM
CloudDiver's Avatar
CloudDiver CloudDiver is offline
The first Bung to go in is the coped bung that sits on the inside of the left tube. The shortest I could get was 1 inch so i had to shorten it and file in an angle to the cope. So I put a 3/8 bolt into the bench vice, cranked it down tight and then put on a leather washer and threaded on the bung using the the curved side of the file to tighten it down. From there I spent a good hour filing the correct height and angle into the cope with several test fits.
