Originally Posted by pushrod243
If the voltage drops below 10volts while cranking most ignitions will not fire. I think your battery is too small or not fully charged. The lithuim batteries will do this.......
I might purchase a cheaper AGM battery to check to see if it fires, then if it does I'll be hitting you up for a Braille battery..
