Old 12-05-2011, 05:18 PM
MotoXcycle's Avatar
MotoXcycle MotoXcycle is offline
Bike Year, Make, Engine: Honda Z50, FZR1000, Wishbone Bobber,
axle plates
OK, went in this morning, the axle base plate was slightly too wide so cut it down to the proper size and fixed the radius so it was perfect.
Now it was time to add the other parts so it looks better and is stronger as well.
First is the two solid parts that the tubes slide into:
Then the final small plates are added:
The the exterior welds are cleaned to make it look like a real motorcycle part:
Looks way better than the foam one!
