Old 12-03-2011, 08:00 AM
MotoXcycle's Avatar
MotoXcycle MotoXcycle is offline
Bike Year, Make, Engine: Honda Z50, FZR1000, Wishbone Bobber,
more progress 4
The shock mount is welded to the shock tube and the bottom of the shock tube is closed to strengthen the assembly.
Using the Jig-Mate tool again the shock tube is carefully tacked to the swing arm pivoting shaft so it is square and properly aligned.
Shock tube welded in place:
Now to make the axle plates, first the raw material is cut:
http://i865.photobucket.com/albums/a...e/IMAG0136.jpg
Then the axle slot is machined:
Starting to take shape:
Radius is cut and steel cleaned up on axle plate:
