Old 03-17-2011, 03:08 PM
donald branscom donald branscom is offline
How I would make a radius tank bottom is to get a section of .065 tubing larger than the backbone to allow a foam pad, and get it rolled to the same radius . Then mark the sides to the depth you want and cut it with a abrasive cut off wheel on your 4 inch hand grinder. Sand the edges.
Wear your face shield.
