Old 06-06-2010, 11:32 AM
STEINBVG STEINBVG is offline
If the upper tree is a pinch/clamp type...
Originally Posted by bugnasty View Post
i think i am to take the caps off here and replace them with the above pic caps?
did those caps come with the kit. Or you bought it in hopes to improve the look of the fork?
Your upper tree might only allow you to use the traditional hd setup in the top tree- that hex bolt you already have- which serves as the plug as well as tightens the leg to the tree from the top.
But if your upper tree is a pinch/clamp type- you can use any plug you want- but for that 2-hole one you need a special wrench and in the process of tightening the plug- you might scratch the hell out of it- not to mention strip those holes.
Also-i'm not even sure what the right one on the picture is?
Good luck
